Questions around converting CMS1000 server from TP Server Software to CMS`
I'm looking at converting a CMS1000 server that shipped with TP server software to run CMS.
In the CMS Installation Guide, it gives fairly simple instructions on deploying the CMS OVA to a specs-based server, as well as mentioning that CMS1000 based deployments have different settings and ship with the software, however it doesn't actually mention how to deploy CMS software to a CMS1000 server that *didn't* ship with CMS software.
Should I just follow the specs-based deployment guide, or is there anything additional I would need to do to ensure it can take full advantage of all vCPUs in the CMS1000?
Patrick Sparkman
You'll follow the CMS Install Guide, the process of deploying the OVA and configuring the VM is the same for the CMS 1000 hardware as it is with a spec-based server.
Patrick Sparkman
Thanks Patrick.
