remote trouble
and.kuznetsov
Hello colleagues!  Possibly after Firmware reset of С40 the microphone from the kit stopped working. We've tried another mic, cable, port - nothing is working. Another problem is that I have only remote access to the C40. Could you please tell me if C40 has some xcommands to troubleshoot this issue. Software version is very old CNC6.0.0.876266.
Wayne DeNardi
You could use the command:
xconf // mic
to get the output of the configuration for the microphones.   There you should be able to see if they are turned on and what their configuration is.
I'm not sure if it's present back on that old TCNC6.0 software or not, but it's in some of the newer software releases (I'd suggest you upgrade if you can) - you can try
xstatus // mic
which will show you whether the mic is seeing any activity:
*s Experimental Audio Input Connectors Microphone 1 Activity: True
*s Experimental Audio Input Connectors Microphone 2 Activity: False
*s Experimental Audio Input Connectors Microphone 3 Activity: False
*s Experimental Audio Input Connectors Microphone 4 Activity: False
And, viewing the web interface of the codec, go to Configuration > Peripherals, and you can see the microphone status there too, as well as being able to click a "Start VU Meter" button to view the activity on the mic.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Thank you for your suggestion.  I'm not sure but the mic configuration seems to be fine
xconf // mic
*c xConfiguration Audio Microphones Mute Enabled: True
*c xConfiguration Audio Input Microphone 1 Type: Microphone
*c xConfiguration Audio Input Microphone 1 Mode: On
*c xConfiguration Audio Input Microphone 1 Level: 14
*c xConfiguration Audio Input Microphone 1 EchoControl Mode: On
*c xConfiguration Audio Input Microphone 1 EchoControl NoiseReduction: On
*c xConfiguration Audio Input Microphone 1 EchoControl Dereverberation: Off
*c xConfiguration Audio Input Microphone 1 Equalizer Mode: Off
*c xConfiguration Audio Input Microphone 1 Equalizer ID: 1
*c xConfiguration Audio Input Microphone 1 VideoAssociation MuteOnInactiveVideo: Off
*c xConfiguration Audio Input Microphone 1 VideoAssociation VideoInputSource: 1
*c xConfiguration Audio Input Microphone 2 Type: Microphone
*c xConfiguration Audio Input Microphone 2 Mode: On
*c xConfiguration Audio Input Microphone 2 Level: 14
*c xConfiguration Audio Input Microphone 2 EchoControl Mode: On
*c xConfiguration Audio Input Microphone 2 EchoControl NoiseReduction: On
*c xConfiguration Audio Input Microphone 2 EchoControl Dereverberation: Off
*c xConfiguration Audio Input Microphone 2 Equalizer Mode: Off
*c xConfiguration Audio Input Microphone 2 Equalizer ID: 1
*c xConfiguration Audio Input Microphone 2 VideoAssociation MuteOnInactiveVideo: Off
*c xConfiguration Audio Input Microphone 2 VideoAssociation VideoInputSource: 1
*c xConfiguration Conference 1 MicUnmuteOnDisconnect Mode: On
*c xConfiguration Experimental Audio Input Microphone 1 EchoControl NoiseReductionMode: Normal
*c xConfiguration Experimental Audio Input Microphone 1 Channel: Mono
*c xConfiguration Experimental Audio Input Microphone 2 EchoControl NoiseReductionMode: Normal
*c xConfiguration Experimental Audio Input Microphone 2 Channel: Mono
** end
In the WEB interface -> Peripherals there is no any information about the microphones as well as  VU meter.
That is the output when i'm making a conference with myself
xstatus // mic
*s Audio Microphones Mute: Off
*s Conference Site 12 MicrophonesMuted: False
*s Experimental Audio Input Connectors Microphone 1 Activity: False
** end
Logs
Sep 23 10:25:30 ppc audio0: Product information
Sep 23 10:25:30 ppc audio0: America
Sep 23 10:25:30 ppc audio0: Main board: H
Sep 23 10:25:30 ppc audio0: Video board: D
Sep 23 10:25:30 ppc audio0: CPU id: 0
Sep 23 10:25:30 ppc audio0: applstart: cpuclock: 300 MHz
Sep 23 10:25:30 ppc audio0: applstart: sysid SYSTEM_AUDIO0
Sep 23 10:25:30 ppc audio0: registerAndWaitForNotify: Sending id = SYSTEM_AUDIO0(11) (184549376)
Sep 23 10:25:30 ppc audio0: Wait for timeout, or incoming message
Sep 23 10:25:35 ppc audio0: registerAndWaitForNotify: Sync message received!
Sep 23 10:25:36 ppc audio0: Audiomcaspraw: nios: Connector index for C40
Sep 23 10:25:36 ppc audio0: S01722
Sep 23 10:25:36 ppc audio0: FPGA Configuration ID 0x4
Sep 23 10:25:36 ppc audio0: SOPC ID=0x0, Time Stamp = 2011-11-09, 13:46
Sep 23 10:25:36 ppc audio0: audiomodule-1: set analog
Sep 23 10:25:36 ppc audio0: applstart, bye
Sep 23 10:25:36 ppc audio0: CLKSYNC: Achieved sync @ 6018031
Sep 23 10:25:41 ppc audio0: audiomodule-0: Timeout, no DNAM connected.
Sep 23 10:25:41 ppc audio0: audiomodule-0: set analog
That's a bit strange because a couple months ago everything worked fine and nobody changed the connections for the mics.
It could be that it's just the mic has failed after all those years of use (or the cabling somewhere between the mic and the codec has failed).   Try using another mic connected directly to the C40 to see if it's still an issue then or not.  It's very unlikely from what you've sent to be a setting on the C40 that has stopped it from working, if it is all connected directly.  The only other possibility is that there is some external audio processor that is performing the mic function and passing the audio in to the codec - this may need to be investigated on site though, and probably not something you can easily determine remotely.
Wayne
