Request for System Status / ProductID using API
Baskaraganesan Natarajan
curl -k -u 'admin:cisco'  -d '<Status><SystemUnit><ProductId status="True"></ProductId></SystemUnit></Status>' http://<IP>/putxml
I am trying to get the API working to get the System Status  and have the following command. It fails with the error below.
<?xml version="1.0"?><ActionError><Reason>No action detected in document.</Reason></ActionError>[
But API is working fine for Callhistory.  I am not sure what I am missing in the Status Query.  Any help in this regard would only be appreciated.
[root@rmsem7appd01 ~]#  curl -k -u 'admin:cisco'  -d '<Command><CallHistory><Get command="True"><DetailLevel>Full</DetailLevel></Get></CallHistory></Command>' http://10.88.85.42/putxml
<Command><CallHistoryGetResult status="OK" item="1">
  <Entry item="0">
    <CallHistoryId item="1">60</CallHistoryId>
Ekaterina Coker
according to the API Reference guide:
You can only use the putxml option for configurations and commands. In other words to ask the codec to do  something. change the time, get the last call data, get current call statistics, etc...
If i understand correctly you are trying to retrieve information and should use the url with getxml?location=path
curl --user admin:cisco --url http://IP/getxml?location=/Status/SystemUnit/ProductId
