Required hardware for voice gateway
kevin crick
Hi All
I am looking for advise on what hardware to use for the following
2 x voice gateway each to handle the following
- 2 x Telkom PRI lines
- 2 x Internodel (E1) lines (30 channels per E1)
- 90 Concurrent call external calls
2 x voice gateway to handle the following
1 x voice gateway to handle the following
- 1 x Internodel (E1) lines (30 channels per E1)
Any feedback will be appreciated.
Thanks in advance
Kevin
Manish Gogna
Hi Kevin,
Ideally you should be checking this with your local SE / Cisco Account team. You may refer the following doc though that gives details of the features and Interfaces supported on 2900 / 3900 and 4000 series routers
http://www.cisco.com/c/en/us/products/collateral/routers/3900-series-integrated-services-routers-isr/data-sheet-c78-729824.html
Manish
