Resolution 1080P don't work
Swisspost4IPT
We have updated Telepresence Endpoints with CE 8.0
We have tried to connect HD sources to a SX10 or MX300 G2 with Resolution with 1080P / 60 Hz.
On the touch Panel we see unknown Resolution
The source is a ClickShare.
Do somebody have any solution or Ideas
Best regards
Roland
Patrick Sparkman
The only supported 1080p resolution the SX10 will accept is 1920x1080@30 (HD1080p), per the data sheet.  Is it possible to change the ClickShare output to use 1080p30 or even 720p30?  You could possibly put a scaler between the SX10 and ClickShare to scale down the incoming video.
Patrick Sparkman
The 1080p30 on the SX10 was only added in the CE8.0.0 version of the software - if you're running TC7.x you cannot input 1080p.
The maximum resolution you can feed in to a SX10 on TC series software is 1280x768 (WXGA).  See this thread: sx10-input-resolution
Edit: Sorry - I didn't see that you're running CE8.0.0 on the endoint already - I've left the above for other's reference.
Note: The SX10 only supports 1080P at 30FPS (1080p30), so you cannot feed a 1080p60 signal in to it, you will either need to drop down the resolution on the device you are connecting, or, as Patrick suggested, insert additional a signal processor/scaler in between to handle the change.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
