Restricting FXS ports to internal calls only
Derek McCormick
I have recently intalled Call Manager 8.5.1 with a H323 Gateway. On the gateway, I have a number of FXS ports for lobby phones. Is there a way I can restrict these phones to allow only internal calls only? Do I need to use COR lists like in Call Manager express or is there a  more practical way?
Derek
frlindse
Hi Derek,
It sounds like these FXS ports are NOT registered to CUCM 8.5.1?  If they aren't, then yes COR lists is the most pratical way to do this.  You could do a "connection plar xxxx" to a receptionist extension and her her/him forward the calls to the correct extension.
