RMA CTS 3010: picture
fatihaarab
I would like to take picture of the CTS 3010 for the RMA certification and we need to take this picture 11 of the ZIP1. But I don’t  know where is it ? Can you please help me ?
Thanks You
Best regards,
Fatiha ARAB
Andrew Beezley
Hello Fatiha - Thank you for your question regarding the CTS 3010.  From what I read, you are needing to identify what is in picture #11 that you attached.  From the looks of it, it appears to be the Sanyo Projector that is mounted under the table (Center).  However, you indicated this is a 3010 which shouldn't have a projector, it should have an LCD for Data Collaboration (Presenation Sharing).  Can you check under the table (Center segment) to see if there is a projector mounted?
Kind regards,
-Andrew
