Room 70 Audio Routing
t.svatek
Level 3
Level 3
Is there a way on Room 70 to route the local microphone signal to an output to connect a recorder?
Tino
Wayne DeNardi
With the newer software releases (CE9.5.0 and later), there is a "feature preview" of the "Audio Console" which is built in to the web interface of the endpoints which replicates the old "CE Console" functionality that was available on some of the older endpoints which allows you to re-route audio within the device.  With this you should be able to add a route for the microphones to an external recording output.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
Wayne
Thanks, Wayne. The Audio Console works well. You just don't see which audio signals from which channel are routed to the conference or not. I also noticed that HDMI audio is not routed through the Echo Canceller. This means that cameras with microphones cannot be used.
