Hello Guys,
recently we installed in our Main Collaboration Room a new Cisco Room Kit EQX, with 3 new Mic Ceiling PRO.
We will also install a Wifi Mic Infrastructure by Shure, with DSP, AP end Wireless MIC dedicated (we will try via AES67, we buyed the AV License..).
We want to have a simple button(with macro) on the tablet to enable/disable the Mic Ceiling PRO when we use the Shure's MIC, and viceversa; we tried some configuration, we used the example "Microphone Controls Macro" on the Codec but doesn't work, i think the problem is related to the MIC ID
const ceilingMics = [5, 6, 7];
const panelMics = [2, 3, 4];
Wich value are used for Ethernet MIC? Can you help me to understand which value we must use for Ethernet Mic?
