Scheduling in a single TMS from multiple Exchange Servers
LT-luisroco
In a multi-tenant enviroment with a single TMS managing the endpoints of different customers, we need to allow scheduling from outlook to some customers.
Can a single TMS works simultaneously with multiple Exchange servers in order to allow to customers in different domains to schedule their conferences?One endpoint can belong just to a customer, so there is not problem of overlapping endpoints between multiple customers.
Marwan ALshawi
to my knowledge TMS can do this, you need to install the exchange integration plugin in those servers to communicate and register with TMS
the only limitations i can see is that TMS will be working with differnt domains AD, and that means TMS has to be standalone not a domain member, and this means users need to login to TMS for booking has to be created in TMS manually or using outlook
