01-21-2013 08:26 PM - edited 03-18-2019 12:28 AM
Is there any way to get a screenshot from endpoint? C20, E20, MXP6000 ?
Solved! Go to Solution.
01-22-2013 12:40 AM
Endpoints does not have HDCP content protection enabled.
You should get a video in device, plug in a video source from the codec and you will be able to take screenshots as much as you`d like
// Marius
01-21-2013 11:06 PM
You view the camera picture via the web interface. Do you need a complete screenshot of the OSD?
01-22-2013 12:30 AM
Yes. We need to make some end-user instructions. As close as possible to real case.
01-22-2013 12:40 AM
// Marius
01-22-2013 02:29 AM
thanks for info
