See S/N Media Board Blade on MCU MPS 800
Hy Dear
I need a help and information, I want to know Serial number of Media board on my MCU MPS 800. how can i get it ?
remotely or i have to Unmount on Media blade in MCU hardware ?
Please give me a suggest and solution for this.
Thankyou very much.
regards
Tomonori Taniguchi
You may check media blade event log file.
Each media blade will automatically create event log file once system start/restart.
The serial number of media blade will print on it.
For example
------------- EVENT LOG SYSTEM INFO -------------
Serial number: 45A02411
Main board: 100750 rev. 02
Boot SW version: Rev. 1.5, 2005-04-04
SW version: J4.6
Date: Mar 16 2011
Codec version: MCU
SW type:
These log files are store under “/tandberg/log” directly.
You might see multiple log files under this directly.
For example (MPS with 2 media blades)
/tandberg/log # ls
eventlog-ll0.1 eventlog-ll0.4 eventlog-ll1.3 lock
eventlog-ll0.2 eventlog-ll1.1 eventlog-ll1.4 save
eventlog-ll0.3 eventlog-ll1.2 index
In this case, just check “eventlog-ll0.1” and “eventlog-ll1.1” files.
The “eventlog-ll0.1” is log from 1st media blade and “eventlog-ll1.1” is log from 2nd media blade.
You may use SSH terminal application and less command to check the log file or WinSCP to access file by GUI base operation.
Tomonori Taniguchi
For example
SW version: J4.6
Date: Mar 16 2011
Codec version: MCU
SW type:
/tandberg/log # ls
Dear Mr Tomonori
Thank you very much for your suggestion.
and i really helpful for that.
once again,
Thanks&Gbu
