Session Border Controller with MCU, VCS, TMS
uddinabu1
Hi All,
We are planning to use Session Border Controller (Cisco or Avaya) with MCU 5320, VCS, TMS.
Could someone please provide SBC product that we can use with MCU?
chuck.brule
Level 4
Level 4
Seeing as this is a Cisco Support community, it would be unusual to find someone advocating for an Avaya SBC, but leaving that aside, I find CUBE to be the most versatile, useful SBC for Enterprise deployments out there.
Although the question is as follows: What are you trying to do? It sounds like you are looking for an IP to IP gateway for strictly TP calling. In which case, you should probably look at VCS-E and Traversal Zones.
Hi Chuck,
We are trying to find option instead of  ISDN gateway 3241 with PRI, can we use Cisco CUBE or Avaya Session Manager for VCS, MCU, TMS and connect to the ITSP provider?
