Setting an access code on VCS-CM sip trunk
rnair
I have a SIP trunk between VCSc and CUCM. If I use a prefix, I can dial out from a C-series endpoint to a DID on the PSTN via the CSS set up on the CUCM. Is there a CPL I can use so that users using the codecs have to dial a special access code before they get to the CUCM and the PSTN?
Thanks.
Martin Koch
There is no out of the box cpl, but feel free to write some endpoint source based mapping your self.
If its fine for you to have one common "prefix" then you could also add that prefix in your search rule,
so instead of dialing a one digit prefix you have to dial 02344523 or something like that.
Also check out if you could register your systems directly to cucm or if you could do some handling
of the access code on the gw or your cucm
