1369
Share video and audio in Jabber
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-28-2021 06:47 AM
Hi all,
I would like to know if there is a way to share the computer audio while presenting a video/website in Jabber.
Thanks!
Labels:
- Labels:
Conferencing
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-28-2021 07:11 AM
You would need to use something like a virtual audio card which could take the input from your mic and PC, mix it and use the output as your input device in Jabber.
java
if this helps, please rate
java
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-30-2021 01:04 PM
Does that solution allow you to share the video's audio AND speak at the same time? Or do you have to disable your mic to share audio and enable it back to be able to speak?
