The parameters for 'Security Certificates CA Add' in XML
Jeff698
Trying to upload a Root CA into VC endpoint with the XML file, got the error '<Command><CAAddResult status="Error">
<Reason>Failed to read X509 certificate</Reason>
</CAAddResult>'
what is required xml format for the CA?
thanks,
Jeff
tomas_vll
 The problem is'nt the need for a body tag?
<?xml version="1.0"?>
<Command>
	<Security>
		<Certificates>
			<CA>
				<Add><body>-----BEGIN CERTIFICATE-----
MIIF1zCCA4ugAwIBAgIQSMdu9UAsd5VNAivwznsfyzBBBgkqhkiG9w0BAQowNKAP
uvDsvjz9WjLU35XmRuPJEV/T90pLR2VCLvwTmAkPHfyWkZzSZaqoNFjsQlWEAUZK
QaAYL89QZy3rsEc=
-----END CERTIFICATE-----</body></Add> </CA> </Certificates> </Security> </Command>
