07-26-2004 08:00 PM - edited 03-17-2019 08:14 PM
I am getting the following disconnect error from the
debug isdn q931, and show isdn status. and when attempting to dial I am getting a fast busy??
Thisis an MGCP gateway with a PRI.
3725#sh isdn stat
Global ISDN Switchtype = primary-ni
ISDN Serial1/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
L2 Protocol = Q.921 L3 Protocol(s) = CCM-MANAGER
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 4
Total Allocated ISDN CCBs = 0
3725#debug isdn q931
debug isdn q931 is ON.
3725#
*Mar 1 00:12:36.847: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0001
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x0081, '4444'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '17133941976'
*Mar 1 00:12:36.923: ISDN Se1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x80
01
*Mar 1 00:12:36.939: ISDN Se1/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x8
001
Cause i = 0x849F - Normal, unspecified
*Mar 1 00:12:37.183: ISDN Se1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x0001
*Mar 1 00:12:37.219: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0
x8001
*Mar 1 00:21:29.443: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0002
Standard = CCITT
*Mar 1 00:21:29.523: ISDN Se1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x80
02
*Mar 1 00:21:29.539: ISDN Se1/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x8
002
*Mar 1 00:21:29.779: ISDN Se1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x0002
*Mar 1 00:21:29.819: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0
x8002
07-27-2004 07:03 AM
Issam
Have you tried changing the plan and type of the call. You can do so with isdn map address command under the channel. I can work with you in the lab on this.
Javed
07-27-2004 07:05 AM
Hi Issam
The release is coming from the switch. Have you tried changing the plan and type of the call. You can do so by using the isdn map addess command under the D channel. I can work with you on this in the lab.
Javed
