Showing results forĀ
Search instead forĀ
Did you mean:Ā
Sip trunk
Hi Guys
i have a task to link CUCME and Avaya server by SIP trunk
i have a CUCME and some cisco ip phones om my site and want to link it with Avaya server located at another branch
so i don`t have problem with configure cisco IP Phones with sip protocol and register them at CUCME
but i have a problem with sip trunk configuration .....
so please, i want a full configuration with explanation
i have
Cisco Router 2911
Cisco switch ------ connect it trunk by 2911
ADSL Modem ---- to connect to other side want to make VPN through ADSL link between 2 sides and i have real IP`s
thanks
Jaime Valencia
This is the Video Over IP community, might want to move this to another area.
Also, if you search CSC and cisco.com, you'll find plenty of examples for SIP trunks, you can also find information in the Cisco interoperability portal.
java
if this helps, please rate
