SIP Video over CUCM 7.x SIP trunk
kursatcoban
Hi All ,
Does CUCM 7.x support SIP Video over SIP trunk ?
For instance     SIP Phone 1 --- Call Manager -(sip trunk ) -- Asterisk --- SIP Phone 2
Can SIP Phone 1 initiate a video call to SIP Phone 2 ?
I took wireshark captures and saw that the SDP messages from SIP Phone 1 is modified by CM.
Thanks for your help,
Kursat
Gordon Charlton
Hi Kursat,
We have been looking at this issue and have found that the SIP trunk providers connection to the PSTN does not support H.323 (H245) traffic in their network.  Have you (or anyone else) found a SIP trunk provider that supports video over SIP?
Cheers,
Gordon
carunach
Yes, CUCM 7.x supports video stream for calls across a SIP trunk. The default behavior of CUCM is to send a SIP INVITE without SDP (also called as SIP Delayed offer)  while placing an outbound call across SIP trunk. Depending on SIP-Phone-2's codec capabilities (as advertised in the SDP offer in 18x / 200 OK SIP response), CUCM will setup audio only or video & audio call.
In your scenario, does the outbound SIP invite from CUCM have SDP? If yes, is MTP enabled on the SIP Trunk?
Arun
If you look for video SIP trunk provider you can get in touch with IVeS and djanah. They provide SIP, h323, h324m and flash video capability.
