ā09-21-2018 04:37 AM
Hi , i have a Integration with Cisco HCS 10.5 , CMS and Lync 2013 on Premises , and Voice / video calls from External Lync clients (ie, connected via 4G or Internet outside the Customer network) for Cisco Internal clients and vice versa, they work randomly (sometimes yes, sometimes dont).
This cal stay connected more or less 30 seg from cisco side ( connected to CMS). I see bot calls in Call logs in CMS but Lync call without any Ć”udio or vĆdeo , and then after 20 or 30 sec , all calls drop.
Can someone help me?
I am debugging from a few day , check cms logs and pcap logs and im unable to solve my problem.
Lync clients in customer LAN works ok.
MX300 - CUCM (HCS) - CMS - FE LYNC - LYNC CLIENT
When the cal comes from outside , something like this MX300 - CUCM (HCS) - CMS - FE LYNC - LYNC EDGE - LYNC CLIENT sometimes work , sometimes dont.
ā09-26-2018 02:35 AM - edited ā09-29-2018 01:36 AM
Hi , thinked my problem was solved by deleting some wrong outbound cal rules to Lync domain .
I had 4 outbound calls rules pointing Lync domain to 2 Lync FE (2 for ip and fqdn FE1 and 2 for ip and fqdn FE2).What i had wrong was that customer enviroment had only 1 FE and second FE ( i thinked) was really a Lync Edge , so i delete outbound cal rules for EDGE , and now i have only 2 rules :
Domain Sip proxy to use local contact domain local from domain trunk type behaviour pri encryption
Lync-domain IP LYNC FE csm fqdn cms domain LYNC stop 10 Encrypted
Lync-domain FQDN LYNC FE csm fqdn cms domain LYNC stop 10 Encrypted
Meanwhile , this problem come back again and i need again some help to solve it.
its something to do with Turn problems ( becouse i use turn for EXP E to webrtc) or do i have to configure Lync fe in cms to put it work?
