09-04-2017 03:14 PM - edited 03-18-2019 01:27 PM
Good Morning.
I have need to know if Theresa some posibility to use spark and registre my sx10 with CUCM.
I know that when startup i need to specify where it's going to register.
I need to call int without expressway or viceversa
Solved! Go to Solution.
09-10-2017 11:32 PM
09-04-2017 03:58 PM
When you say "call int" are you referring to "call internal" or "call internet" ??
When you register on CUCM, it uses CUCM as call control and you would be able to call internal registered endpoints on CUCM, however you won't be able to call any where else, for e.g.any B2B calls or even calls to any endpoint on SPARK.
However if you are looking for any other calls like B2B or you want to register the endpoint on SPARK and wants to reach both spark endpoints and calling to CUCM endpoints, you need Expressway to do that.
Alok
09-04-2017 04:20 PM
I mean "internal"
so you recommend me to register my SX10 in Spark and the use Expressway to call internaly and Externaly by number?
there is some form of calling without indicating the domain?
09-10-2017 11:32 PM
