06-30-2017 12:25 PM - edited 03-18-2019 01:15 PM
I noticed the Spark Board has a web server built into it and I wanted to poke around a bit but the standard UN: admin and Password: Blank doesn't work as the default. I was wondering if the unit is currently accessible via its web browser? or if it has a Special UN & PW. Thanks for your time. DK
07-01-2017 09:08 PM
Once the endpoint is registered on Spark, you cannot access the web interface using an admin login. Only the Spark Admin portal gives access to a very limited subset of settings. This can be a bit frustrating but this is by design, to make things simpler.
08-17-2017 01:22 AM
My endpoint is registered on spark & i want to disable proximity on my spark board.
Is it possible to change such settings from spark admin portal or any other ways to customize such settings ?
08-17-2017 01:39 PM
I don't think it's possible to disable Proximity on Spark registered endpoints, however it appears the workaround is to disable it in the Proximity/Spark application itself: Stop Automatically Connecting to a Cisco Spark Room Device.
12-19-2017 08:39 PM
Hi All,
I have a questions about Spark Board.
1. If Spark Board get offline with the cloud or internet, it can be share the content via hdmi input ?
2. What happen if Spark Board OS error, it can be Sparkboard act like Monitor only ?
thanks for the response
rgds,
Charis
12-19-2017 09:53 PM - edited 12-19-2017 09:54 PM
If the Spark Board is off-line, then it won't be able to share the content with other participants as it won't be on-line to do so, however it will still be able to display a device connected locally via HDMI on the screen.
If the Board's OS dies in that manner, then there will be no way for it to be switched to display the content on the screen, so, no, it will not act like a standard computer monitor. In this case, you will need to either fix the software via the available mechanisms, or, it's more likely that there is a hardware failure requiring the board is RMA'd.
Please remember to mark helpful responses and to set your question as answered if appropriate.
