Speaker Tracking with goosneck
bashar-albdour
hi
I am currently using the Cisco Codec EQ in combination with a Quad Camera and two PTZ cameras. For audio, I am using 21 gooseneck microphones from televic (D-Cereno set).
I would like to implement speaker tracking using this setup.
Could you please advise on how to enable and configure speaker tracking with these cameras and microphones?
Thank you in advance for your support.
What are the PTZ used ? for CrossView?
Have you completed the Multi camera director setup ?
AFAIK, even with the third-party mic, the camera must track the speaker, as the Quad Cam has built-in mics.What challenges are you facing now?
Response Signature
yes the PTZ is for the cross view , the challenge is that I want to know how the speaker tracking of the cameras will work with the gooseneck microphones from Televic , like is it compatible with the VC system (quad and codec)
mic connection : all the 21 mic is connected to D-Cereno central unit , audio output from the central unit to my DSP, audio output from DSP to codec EQ
