Standalone SX10 ip dialing to polycom MCU RMX500
fei ge
Hi,Experts
Have you ever test the situation that standalone SX10 ip dialing to polycom MCU RMX500?is it possible(no vcs or cucm)
vikdutta
Why not ?  It is possible.
Check where RMX 500 is placed. ie in Lan, DMZ or public internet.
If RMX is on lan>  just dial the dialable pattern from SX 10 which RMX understands ie conf code, uri, ip etc to join a meeting.
If RMX is on public, configure nat ip on SX 10. allow SX 10 subnet on Firewall, throw a call to RMX.
Note***  you will face some media issues initially. firewall should be flexible enough to be configured
to allow rtp dual stream h239/bfcp. etc etc.
//VD
If the Polycom has been configured to support SIP in-dial then there should be no issues.
If the Polycom is H.323 only, you will need a VCS (or similar) to do the interworking between SIP and H.323.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
