Cisco VC endpoint cheap Recording method
Chi Fai Leung
I'm designing a cheap method to make the recording on Cisco VC point to point call.
Cisco SX20 (HDMI-output-1) ------ HDMI splitter -----(separate two HDMI output) ------ Monitor ===== Video Recording Server / Hardware
(I must restrict to record the video only [Must not record the audio] )
Anyone try this cheap method to record video conference?
- EX90, EX60, DX70, DX80, SX20, C40, SX80 .... all can work on all Cisco VC endpoint / codec?
- Two endpoint is Cisco brand, that would make the encryption video, which is Layer 3 encryption and will not affect the HDMI splitter recording?
Wayne DeNardi
If you only want the video, then you will need a little more than that, as the far end audio is usually sent out the HDMI connector.  You'd need to use an HDMI Audio De-Embedder to strip this out for your video only.
If you need to record the local video as well, you'd need to turn on the self-view as well so the local camera appears on the screen (in a window) as well as the far end video.
(And, no, the encryption on the network link, or even on the call will not affect the HDMI output).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
