SX-80 +speakertrack + presenter track
Cartwright
In the admin guide for SX80 it indicates the audience camera=speakertrack, with a presenter camera = presenter track is a valid setup when in briefing room mode.  p57
on p59 it indicates automatic switching mode will switch  from the presenter camera to the individual in the audience asking the question on audience camera automatically..
this makes it appear that both speakertrack and presentertrack are operating at the same time.
however on p52 it says speakertrack and presenter track cannot be used simultaneously... one disables the other....
we were thinking this solution would be ideal for a room with a group of folks basically sitting in a box, where the speakertrack would cover most of the group from one end of the room, and those sitting with their back to the speakertrack would be covered by the presentertrack camera from the opposite side of the room.
is this going to work on sx80 with these devices, or is a different solution required?
Wayne DeNardi
There were some issues with this in some of the software releases.  CE9.2.1 has re-enabled the briefing room functionality that had been removed in some of the previous releases.  Which software release are you using on your SX80?
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
we will be running the most recent version,
its an executive room so they are looking for autoswitching solution from front camera and back.  the new version does seem to bring some fixes to the table. thanks for your input
