sx 80 with ce8, how to disable remote camera control
Danny Meyer
Level 4
Level 4
Hello.
I would like to prevent remote users to move my local camera (remote camera control).
Tried to find any hint how to, but I am not able to solve it.
If I turn off "Camera Control - Mode" under Connector 1, then the whole camera control locally is also disabled.
In older systems, I remember that this was a clearly shown option.
Thanks for your advice.
Danny
Patrick Sparkman
I checked and there doesn't seem to be a way to disable FECC, unless the endpoint is managed by CUCM.  See the TelePresence Endpoints Deployment Guide for CUCM 11.0.1 (CE8.0) on pg 17.
Thanks, Patrick. I almost got nuts searching. Rather strange. This unit is still on the VCS, but I really have to check if under CUCM there are options.
Danny
