Showing results forĀ
Search instead forĀ
Did you mean:Ā
SX10 layouts
dblackie1
Hi, I'm running software version  ce 9.1.4,3 which has 4 layout options (Equal, Overlay, Prominent & Single), do you get anymore options with any of the newer software versions? Ta Davie.
Anurag Srivastava1
I think no these are the only default 4 layouts in SX10.
Also due to the hardware capability i think it also does not support macro framework so that you can customize your own as in new gen endpoints.
Please rate if it is helpful and mark as accepted solution if applicable...
Please rate if it is helpful and mark as accepted solution if applicable....
Anurag Srivastava1
