02-18-2019 12:16 AM - edited 03-18-2019 02:39 PM
Hello.
I have 4x Cisco SX10 - managed manually
I use it to call SIP between each other and H323 to use 'cloud'. They work great!. When i set up this hardware once - I do not change configuration but the problem is that every few days (restart) a several settings are lost:
- H323 mode sets up - OFF (normally is ON) http://ip/web/config/NetworkServices option: H323 Mode
- HTTP mode sets up HTTPS (normally is HTTP+HTTPS) http://ip/web/config/NetworkServices option: HTTP mode
- System Unit Name sets up - clear/blank (normally is set up) http://ip/web/config/SystemUnit option: Name
- Favorites list set up clear (empy) (normally i have few entries)
This what i noticed. Maybe other options also change but the most important for me are the ones above.
In http://ip/web/persistency all options are set up to Persistent. And this 'missing' config thing shows up - not every restart bur random.
Model: Cisco SX10
Firmware: ce 9.6.1 4516ae5aaa1 2018-12-12 (but the same was on earlier versions)
The unit are't connected to any system... the appear as 'separate being'
Have any of you encountered such a problem?
This is very annoying and disturbing at work.
Solved! Go to Solution.
06-06-2019 01:15 AM
After update the all Cisco SX10 to ce 9.7.1 - i think problem solved. Because from few weeks there no problem with 'not holding settings'. Everything is OK. (for now)
02-18-2019 06:35 AM
Log into the admin interface of the codec via the IP.
Go to Setup and select System Configuration.
Click on Provisioning on the left side and change the mode from CUCM to None.
02-19-2019 02:04 AM
Unfortunately this option is set up - OFF (screen below)
02-19-2019 06:09 AM
Try disabling CDP Mode, under NetworkServices. Then reboot the codec.
02-20-2019 12:47 AM
OK i done that. We see if helps.
02-19-2019 12:04 PM
What do you use for Call Control? If you have a CUCM on your Infrastructure then check to see if they are Auto-registered to it, as that might also erase all settings if the profile is not configured correctly on CUCM.
02-20-2019 12:49 AM
02-19-2019 07:17 PM - edited 02-19-2019 07:20 PM
Also check on the endpoint that someone hasn't enable non-persistent mode. This can be found on the web interface under Security > Non-persistent mode. By default, everything shoud be Persistent.
You could also do a factory reset on the device, then reconfigure it - that will confirm whether there is some setting on it them that is affecting the behaviour, or whether there is perhaps some external system (TMS/CUCM/etc) that is overwriting your settings.
Please remember to mark helpful responses and to set your question as answered if appropriate.
02-20-2019 12:55 AM
06-06-2019 01:15 AM
