02-26-2019 03:32 PM
I'm having a weird problem and would like to see if someone out there in the Cisco community has experienced something similar and see if I can get some help to find a solution for my issue.
So I have a few SX10, SX20, and SX80s and I'm using VCS controller and expressway.
Everything works perfectly fine except for the last SX10 I installed. For some reason I cannot connect calls to or from this new SX10 to/from other endpoints in the same domain. Doesn't work on both h323 or sip. It just rings, I answer the call, it keeps ringing, it will not complete the call so it just drops it after a few seconds. Checked firewall logs and traffic routing; everything looks correct and no traffic is being dropped. Has anyone seen this before? This connectiong is going through a vpn tunnel since this endpoint is at a different location. Again, no traffic is being dropped on any firewall. VCS logs show all searches are fine. Call logs look good too. Any ideas would be greatly appreciated.
02-26-2019 08:41 PM
03-06-2019 06:31 AM
03-06-2019 07:16 AM - edited 03-06-2019 07:17 AM
Initially, could you check if there is SIP/H323 inspection activated on your firewall that may affect this kind of calls (withing the VPN tunnel)?
Moreover, can you confirm that peer2peer connectivity is routed correct, ie both endpoints are able to ping each-other?
You may also engage a TAC engineer to check the logs that you can capture by following the procedure described below:
George
