SX10/Webex
chinojosa
I have an SX10 that I would like to get working with Webex, how would I go about doing so? Currently have it setup on CUCM.  Would I have to purchase a CMR?
Patrick McCarthy
CMR is part of the Webex service. If you have a Webex Annuity contract you are entitled to it for free, check with your service provider. To connect to it you will need VCS/Expressway set up in your environment to allow you to dial public URI's with your SX10. Try dialing 89274447@cisco.com - if you see my splash screen you can dial out, if it fails you aren't set up to allow outbound URI dialing, that would have to be resolved as well.
Patrick McCarthy
