05-21-2013 06:04 AM - edited 03-18-2019 01:08 AM
the customer wants to buy SX20 and Ex90 , and he needs information in my side, the Questions :
- Does he need a VCS ? or CUCM it is enogh for that ?
- what is the CUCM version is supported for SX20 , EX90 ?
- how to add these endpoints to CUCM ?
- regarding the Bandwidth , what is the good the bandwitdth to make the video and audio calls are very clear and high quality ? up to 6 Mbps ?
- what is the version for SX20 , EX90 should be suppoeted with CUCM or VCS ?
please your answers are very important for me
thanks
Solved! Go to Solution.
05-21-2013 09:10 AM
Hi Lkayyali,
please find the BW requirements depending upon resolutions.
optimal definition profiles for system supporting 1080p
w288p30 w448p30 w576p30 720p30 1080p30
Normal 256kbit/s 512kbit/s 768kbit/s 1152kbit/s 2560kbit.s
medium 128kbits/s 384kbit/s 512kbit/s 1152 kbits/s 1920kbit/s
high 128kbit/s 256kbit/s 512kbit/s 768kbit/s 1472kbit/s
optimal definition profiles for system supporting 720p60
w144p60 w288p60 w448p60 w576p60 720p60
Normal 128kbit/s 512kbit/s 1152kbit/s 1452kbit/s 2240kbit.s
medium 128kbits/s 384kbit/s 768kbit/s 1152 kbits/s 1920kbit/s
high 128kbit/s 256kbit/s 512kbit/s 768kbit/s 1152kbit/s
please feel free to rate this answer in case it is helpful
05-21-2013 11:55 PM
Depends on your requirements.
If you only want to use your video endpoints internally, CUCM will be sufficient.
If you got third party endpoints or want to do B2B calls, you need the VCS Control and Expressway.
05-21-2013 07:35 AM
Hi Lkayyali,
1. SX20 and C20 can use both VCS as well as CUCM as gatekepper for registeration. they can registered on VCS as h.323 as well as SIP unit. for CUCM they can be registered as SIP device. it depends upon the type of deployment in your network. if your network use CUCM then you can register SX20, C20 on CUCM for calls.
2. for native registration, C20 requires CUCM to be on 8.6.1 or later and SX20 requires CUCM 8.6.2 or later along with device pack for SX20.
3. steps to register the endpoint on CUCM, please find the document : http://www.cisco.com/en/US/docs/telepresence/endpoint/codec-c-series/tc5/administration_guide/cts_endpoint_administration_ucm86_quick_start_guide_tc50.pdf
4. SX20 and C20 should be on TC 5 or later for CUCM deployment.
05-21-2013 08:49 AM
Dear Amit
first of all , thanks for your reply
regarding the bandwith , what is the remonended bandwidth for WAN/LAN to make the audio and Vedio very clear and high quality ?
05-21-2013 09:10 AM
Hi Lkayyali,
05-21-2013 10:44 PM
Dear Amit
last question plz
the customer has WAN connection between Kuwait and USA (Miami) , and has a firewall between Kuwait and USA , my Question :
- is it necessary to need to VCS control and VCS expressway with CUCM ? or CUCM enough ?
- what you prefer ?
05-21-2013 11:55 PM
05-22-2013 12:08 AM
thanks all
