Software version ce 9.13.2
SX20
This problem relates to Webex Meetings and the mute fiasco!
I have a situation where room systems users in a Webex meeting at the touch10 need to to click "Keypad" and enter
*6 to mute/unmute
2 to cycle through the various Webex meetings layouts such as Grid view
I have used the UI Extensions editor to add a webex button when in call and that button produces a new panel where I plan to put a mute/unmute button and a "view cycle" button, share etc.
My problem is that on ce 9 " xCommand DTMFSend DTMFString" is not available.
So in my macro I need to find the right command to send the "*6" and other keypad commands.
Notes
1.The "Key item" command does not have a "*" available.
2.O ce 9 " xCommand DTMFSend DTMFString" is not available. I tried it nonetheless and it failed.
3.The "dial" command does not work as it tries to make a new call.
Does anybody know the right command to send "*6". Thank you.
This is what I have so far
const xapi = require('xapi');
xapi.event.on('UserInterface Extensions Widget Action', webexmute);
function webexmute(event) {
if (event.WidgetId === 'webexmute' && event.Type === 'clicked') {
xapi.command(' ?????? ', { ValuespaceRef: '*6' });
