04-04-2015 12:48 AM - edited 03-18-2019 04:17 AM
Hi Team,
While in a call in SX20 i am not able to share a presentation, checked without call also same presentation is not getting on second display even system as a Dual display license.
Second display shows blank and black screen please share if any configuration has to be changed.
04-04-2015 12:26 PM
Check to make sure the following is configured on the SX20, and if it isn't, do so and test again to see if the presentation appears on your second monitor.
If MonitorRole is set to "First", it will display the remote participants. If set to "Second", it will display presentation content, as well as and selfview as well if you'd like it on the second monitor.
If you'd like selfview to appear on the second screen, do the following as well:
04-07-2015 04:50 AM
Hi Patrick,
One of our customer is using SX20 and its a standalone system configured with Ip subnet and gateway.
in the idle mode or in VC call continues getting a incoming call and the incoming call shows with the extension number and @ and SX20 codec IP address.
In idle mode sometimes a miscall shows upto 1000 miscall this is irritating the conference call.
Please suggest what to do.
Thanks & Regards
Laxminarayan
04-07-2015 07:52 AM
EDIT: I noticed you created a new discussion with the same question, as a result I moved my original comment that was made here to that discussion where you asked the same question, unknow-miscall-are-getting-sx20.
