04-21-2021 12:46 PM
I'm seeking some advice on getting a SX20 to display on a second monitor. The unit appears to be noticing the monitor, but I cannot get the status to update to show self view on the second monitor despite changing settings in the configurations.
Screenshots of settings attached. Any guidance?
Monitor config:
Output config:
Selfview config:
Selfview status:
Solved! Go to Solution.
04-22-2021 09:26 AM
Update: I was able to get the second screen recognized after power cycling. I was attempting to change the settings during a call, so perhaps the call was preventing the status change?
04-21-2021 09:59 PM
You have selfview mode set to Off. You need to set it to On (or activate Self View with the appropriate option from your Touch10 or TRC6 Remote)
Please remember to mark helpful responses and to set your question as answered if appropriate.
04-22-2021 05:56 AM
The problem was when I turned it on, it was still appearing on the first screen, regardless of what settings I changed.
04-22-2021 09:26 AM
