I had an SX20, registered to CUCM, that was running TC7.3.14.164ea0b. I configured the SX20 to upgrade to CE8.3.8 (as a stepping stone to CE9)
The unit downloaded the CE8 firmware, installed it & rebooted. But after rebooting, the unit fails to come up cleanly. There's nothing on the unit's video output. I can still login to the unit via the web interface, and it reports:
"An error occurred when communicating with the system.
The web interface has no connection to the XAPI.
Maintenance Mode
The system is currently not responding. This might be caused by the system entering maintenance mode."
I've tried uploading the pkg version of CE8.3.8 firmware to the unit direct via its web interface, but still the same.
I couldn't see anything in the CE8.3 release notes about having to go via a prior/special CE8 version prior to CE8.3
What can I do to resurrect this unit?
Thank you.
Please rate all helpful posts.
