SX20 USB PORT USAGE?
MARTIN DELANEY
Is it possible to use the USB port to control a monitor?
Patrick Sparkman
According to the admin guide, the two USB ports on the codec are used for serial communication via RS-232 adapter. In order to control external equipment, you'd have to use In-room Controls with a third-party control system such as Crestron or AMX will be required.
