12-14-2018 03:22 PM - edited 03-18-2019 02:31 PM
I'm trying to see if there is a way to send different sources using the SX80 camera input.
I have my input sources going into a video switcher, and need to output those sources selected sources "Program" through the Camera Input on the codec.
When I do this, all I get is black form the Codec send and can never see the selected source.
Is there something I'm missing?
Thank you!
Solved! Go to Solution.
12-16-2018 06:45 PM
You will need to make sure that the output from your switcher is sending something that is compliant with what the input on the SX80 will accept.
You also need to make sure that it isn't marked with HDCP being required - if the codec detects HDCP content, it will correctly disable the input as HDCP protected content should not be transmitted.
Please remember to mark helpful responses and to set your question as answered if appropriate.
12-16-2018 06:45 PM
