SX80 Going into Standby when doing a presentation only
Andrew Dighton
Just a quick post to confirm that this is normal for the SX80.  If the system is not in a call and just being used to view presentations locally the system goes into standby at the preset value.
Is this normal, should the SX80 not go into standby when being used for presentation?
Thank you
Andrew
John Buckley
Set the codec Standby Delay ON
Set the codec Standby Delay to between 0 and 480 minutes.
