SX80 Live input source switching for HDMI 1,2,3 etc.
Duane Viedt
Howdy folks,
From time to time we need to switch a camera input from the web interface during a live call. We can do this successfully with an SX20 but with a new SX80 installation, the live source selection doesn't change inputs. Changing inputs in the room with the touch 10 works as it should.
I have noticed some of the settings in the SX80 require a restart to 'take' so just wondering if anyone else has experienced this.
Running SW TC7.3.6
Thx!
Patrick Sparkman
There is a bug with the web interface where the main camera doesn't want to change, see CSCva64137, the fix is to upgrade to either TC7.3.7 or CE8.2.2.  If you don't want to upgrade, there is a workaround mentioned in tread camera-switching where you create presets and recall them from the web interface.
Patrick Sparkman
Thanks for the quick reply Patrick! Exactly what I was looking for.
Duane
