SX80 log settings
rpbarham
Hi all,
Just a quick question regarding the SX80 endpoint. Our customer installed several of these devices,and they are sending out alerts/alarms and we would like to minimize the output. Is there a way to change the log settings on the SX80,or change the level, or even disable certain logs ?
Anurag Srivastava1
Please provide more details of the kind of alarms which and where you are getting?
Also by default all the log level is info or warning only if you have not done anything to increase debug level from CLI or not enabled the extended logging.
Please rate if it is helpful..
Please rate if it is helpful and mark as accepted solution if applicable....
