Sx80 Microphones
Shy Solenko
If i connect 2-3 mics to the sx80, can i mute only one or two of them?
Shy
Patrick Sparkman
If you're using the TelePresence Microphone 60 that comes with the SX80, no you can't.  However if you're using third-party microphones with their own independent on/off button you can.  Muting any one of the TelePresence Microphone 60 will mute the entire SX80 system and any connected microphones.
Swoodruff1
If you have serial or SSH control of the SX80, you could send it an xCommand in a couple ways:
xConfiguration Audio Input Microphone [1..8] Level
Define the audio level of the Microphone input connector.
See the Audio Level table in the Physical Interface Guide for the codec for a complete overview
of the values represented in dB.
Requires user role: ADMIN, INTEGRATOR
Default value: 58
USAGE:
xConfiguration Audio Input Microphone n Level: Level
where
n: Unique ID that identifies the microphone input. Range: 1..8
Level: Integer (0..70)
Select a value between 0 and 70, in steps of 1 dB.
xConfiguration Audio Input Microphone [1..8] Mode
Disable or enable audio on the microphone connector.
Default value: On
USAGE:
xConfiguration Audio Input Microphone n Mode: Mode
where
Mode: Off/On
Off: Disable the audio input microphone connector.
On: Enable the audio input microphone connector
Just to add to this, it's now possible to do this using macros, introduced in CE9.2.1. You can create an In-Room Control panel and using macros, control individual microphones.
