SX80 operating temperature
bravo
According to the data sheet for the SX80 the codec has an ambient temperature range of 0°C to 40°C (32 to 104° F).
Is there an actual operating temp listed anywhere for the codec which can be used to match against the information provided in an xstatus?
We are looking to make sure the codec is operating at proper temperature levels.
Thank you,
Jose Bravo
Visitec
bravo
We currently have codecs operating at over 155°F according to the xstatus information.
155F is not an issue, but I would try to keep it below 180F or so. The C-series will shut down when it get close to max internal operating temperature, so I would assume the SX80 will have a similar built-in fail-safe. (I can't recall what the max internal op temp is, but it's pretty high.)
/jens
Please rate replies and mark question(s) as "answered if applicable.
Please rate replies and mark question(s) as "answered" if applicable.
I don't believe that the SX80 (I don't have one here to double check, but checked on some C series endpoints) will show the ambient (room) temperature - they only report the system operating temperature.
I'd say that if the room that the people who are using the SX80 in is below 0°C, or higher than 40°C, you'd be getting some complaints.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
