SX80 under ce 8.2.1 Final e9daf06 using TRC5 or TRC6
all,
is it possible to disable the 10" touch device and use the standard remote control such as the TRC5 or TRC6 instead to operate the system on the SX80 with ce 8.2.1 installed ?
rgds
Andy
Patrick Sparkman
Remote control isn't supported, this is because the software running on the SX80 doesn't provide any type of interactive menu for use with a remote control, so it won't work. You must use the Touch 10 to control the SX80, the only other method is by means of some third-party control system such as Crestron or AMX.
Wayne DeNardi
You can disable the touch10 (if you are going to use some other form of external control), but you cannot use a remote control with the SX80.
This has been mentioned a couple of times before in these forums: sx-80-questions is one example.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
