04-20-2016 05:28 AM - edited 03-18-2019 05:50 AM
I received an MX700 videoconferencing system on the web and ssh, it is seen as SX80.
On the Cisco site https: //cway.cisco.con/sncheck/ serial number is seen as a MX700.
How can see by MX700.
SN: FTT200800H6
xstatus SystemUnit ProductId: "Cisco TelePresence SX80"
04-20-2016 06:13 AM
Hi Cyrille,
was there an RMA of the codec ? MX700/MX800 are using a SX80 and with a Option key you can tell the SX80 codec you are a MX800 or MX700 System.
If the System was delivered in that way you should open a Cisco TAC Case to request the required license. I think you will need the original Sales Order number to get the required license from TAC.
Sebastian
02-15-2017 06:46 AM
Is there any bug id related to this issue?
Fird
02-15-2017 07:43 AM
What do you mean by BEMS ?
Firdaush
04-20-2016 07:04 AM
You should contact TAC, they can generate the option key that you can apply to the MX700 so that it will appear with the correct product ID.
