Taking CCNP voice
Lim Seow Hua
Hi all,
I am planning to  take the CCNP Voice certification by this year. But I am not sure that  do I need to take the CCNA voice cert before take CCNP voice.
I am a CCNA certified 3 years ago and my cert is going to expire on this year May, 2011.
Can anyone advice on this?
Joseph Martini
Looks like you do need to have the CCNA Voice prior to starting the CCNP Voice: https://learningnetwork.cisco.com/message/127342
slakhanp
Hi Lim,
The  CCNP Voice consists of 5 exams. You have to take all exams to complet ethe CCNP Voice.
If you sit for any of the 5 exams before the expiration date of CCNA, you'll be recertified in CCNA.
HTH!
Please rate.
Mario Garcia
Level 3
Level 3
Hi Lim,
You can take the CVOICE exam first and that will make you CCNA Voice, so then 4 additional tests to become CCNP Voice
Good luck
-Mario
