Tandberg C20 Audio target change
kahuna
Our C20 Conference system has 2 type audio output.
HDMİ (LG TV) and RCA (Creative 2+1 audio system).
We want to use RCA, but we couldn't change from HDMI to RCA.
Audio came from HDMI TV.  How can I change audio output  from HDMI TV to RCA 2+1 speaker system?
PJMack
Level 7
Level 7
You didn't mention what SW version you are running, but go into the web GUI, go to configuration, audio, and then outputs. audio on the HDMI out will be on - turn that off. There is probably then a line out? Not sure, I don't have a C20 anymore, but that's where any settings will be to turn it on/off or adjust levels.
Wayne DeNardi
The C20s are a very old endpoint model and went completely end of support over a year ago on 31 August 2018.
I'd highly recommend that you consider upgrading them to a newer and more supportable endpoint (such as one of the Cisco Room Series).
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
