TANDBERG EDGE 95 MXP
Good Day,
I am requesting information and Support regarding the Tandberg Edge 95 MXP(Serial #: 26A79316, specifically:
- Is this device authorized to be operated on a Secure Network?
- Does is pose a significant Vulnerability Security Risk?
Thank you,
Efrem Williams
email: efrem.williams.ctr@usmc.mil
Leonardo Santana
This device is too old it´s not sold and supported anymore.
So there is no software updates to correct sec vulnerabilities.
The Cisco TelePresence System Edge MXP Series has been retired and is no longer supported.
  • End-of-Sale Date: 2013-05-14
  • End-of-Support Date: 2018-05-31
Leonardo Santana
*** Rate All Helpful Responses***
Thank you very much!
Thank you for your technical reply to my earlier posed question.
Your answer was an adequate solution.
Thank you.
