TC Console not working with SX80
petfjerm
Having issues with TC Console and Cisco SX 80. Can connect to the codec, but when I'm trying to sync or apply the layout, I get an error msg saying 'Unable to upload startup script: 401'. Tried from different computers. And yes, XMLAPI mode is on. Any ideas?
TC Console version: 7.3.0
Software version: TC7.3.3
//Petter
Might be a dumb question - but have you checked that the username and password you are using is valid on the endpoint, and that the user account you are using has the "Admin" role?
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Hi Wayne, and thanks for your reply.
The account is Admin. Just did some logging on the unit. and the msg is pretty clear. But dunno why. Will t-shoot some more.
User Admin(1004) about to execute command '/Video/Layout/LoadDb Type: Custom' from .
2019-04-23T09:05:25.877+02:00 LCR1 appl[1233]: 1417.74 APPL_Layout ERROR: Failed to build layout database: filepath error
//Petter
You could have a corrupted layout on the unit. Try removing everything that’s there then add it again.
Wayne
