04-18-2013 12:39 PM - edited 03-18-2019 12:58 AM
Our 6.0 EX90 endpoints do not show up when you run sh cdp neighbors on the cisco switches they are connected too. I could not find a bug in the toolkit on this. I have the voice vlan set to auto and it is set up the same as some of our 5.1.7 endpoints that do show up in discovery. Any ideas on a setting to fix this?
04-18-2013 09:54 PM
the logs would show how CDP gets started :
http://10.60.142.199/wsgi/logs/file/current?file=console
Starting cdpep # This file is generated from /etc/init.d/S09cdpep at # Thu Apr 18 04:41:58 UTC 2013 CDPEP_VLAN_VOICE_STATUS=Good CDPEP_VLAN_VOICE_MODE=Off CDPEP_VLAN_VOICE_ID=1
If you have root access to your EX90 you can run tcpdump to check for CDP packets leaving EX90 :
[dderidde-ex90-home:~] $ tcpdump -s0 'ether[20:2] == 0x2000' -vv
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
06:52:23.290824 CDPv2, ttl: 180s, checksum: 692 (unverified), length 92
Device-ID (0x01), length: 15 bytes: 'SEP4055390CEF66'
Port-ID (0x03), length: 4 bytes: 'eth0'
Capability (0x04), length: 4 bytes: (0x00000090): L3 capable
Version String (0x05), length: 14 bytes:
TC5.1.5.297625
Platform (0x06), length: 14 bytes: 'CTS-CODEC-EX90'
Address (0x02), length: 13 bytes: IPv4 (1) ams-dderidde-8916.cisco.com
(type CNTRL C to stop the tcpdump)
Check whether cdp process is running :
[dderidde-ex90-home:~] $ ps -aef | grep cdp
root 1709 1 0 Apr18 ? 00:00:00 cdpep Falcon.EX90/f Off
root 24677 15720 0 06:54 pts/0 00:00:00 grep cdp
Danny.
04-19-2013 05:37 AM
This is what I found in the logs
Starting cdpep
CDP: VLAN Mode=Auto
CDP: Mode=Off
How do we turn this on? We only have had this problem with the new TC6.0 software. we have over 50 5.1.7 units in our network and they all work fine with the same setup.
04-26-2013 08:09 AM
I tried TC6.1.0 with these settings :
xConfiguration Network 1 VLAN Voice Mode: Auto
xConfiguration Network 1 VLAN Voice VlanId: 1
My console log says :
Starting cdpep
CDP: VLAN Mode=Auto
CDP: Mode=Off
VLAN: configuring vlanless
VLAN: configuring Endeavour vlan 4090
I then tried to check CDP messages using tcpdump :
17:01:56.164552 CDPv2, ttl: 180s, checksum: 692 (unverified), length 93
Version String (0x05), length: 15 bytes:
TC6.1.0 c4723e9
Even with this mode off we send CDP. I think the mode in this context is whether we have voice VLAN or not. My 892 router "sees" my EX90 and Touch Panel.
show cdp neighbors detail
Device ID: SEP005060061E55
Entry address(es):
IP address: 10.60.142.200
Platform: CTS-CODEC-inTouch, Capabilities: Host
Interface: FastEthernet1, Port ID (outgoing port): eth0
Holdtime : 156 sec
Version :
TT6.1.0 c4723e9
advertisement version: 2
Device ID: SEP4055390CEF66
Entry address(es):
Platform: CTS-CODEC-EX90, Capabilities: Host
Interface: FastEthernet3, Port ID (outgoing port): eth0
Holdtime : 138 sec
Version :
TC6.1.0 c4723e9
xstatus //cdp
*s Network 1 CDP Platform: "Cisco 892"
*s Network 1 CDP Version: "Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.1(4)M2, RELEASE SOFTWARE (fc1)*Technical Support: http://www.cisco.com/techsupport*Copyright (c) 1986-2011 by Cisco Systems, Inc.*Compiled Tue 27-Sep-11 01:15 by prod_rel_team"
*s Network 1 CDP Capabilities: "0x0029"
*s Network 1 CDP DeviceId: "ams-dderidde-891.cisco.com"
*s Network 1 CDP PortID: "FastEthernet3"
*s Network 1 CDP Duplex: "Full"
*s Network 1 CDP VTPMgmtDomain: ""
*s Network 1 CDP Address: "10.60.142.193"
*s Network 1 CDP PrimaryMgmtAddress: ""
*s Network 1 CDP SysName: ""
*s Network 1 CDP SysObjectID: ""
*s Network 1 CDP VoIPApplianceVlanID: "None"
** end
OK
04-26-2013 08:38 AM
I followed you through everything seems okay until I show CDP on my switch and it is not here and this is what I get from my codec
xstatus //cdp
*s Network 1 CDP Platform: ""
*s Network 1 CDP Version: ""
*s Network 1 CDP Capabilities: ""
*s Network 1 CDP DeviceId: ""
*s Network 1 CDP PortID: ""
*s Network 1 CDP Duplex: ""
*s Network 1 CDP Address: ""
*s Network 1 CDP VoIPApplianceVlanID: ""
** end
For whatever reason its not getting anything back. But it is sending CDP when I was in root on the codec.
